Wi-Fi Menu / 9.4 - Permissions
Setting permissions for data manipulation and the ability to adjust MiniHPC via On-line cloud or the local network.
– enabling this option will send the measured data from MiniHPC (temperatures, energy, relay statuses, etc.) to the online cloud at regular 60-second intervals.
– enabling this option will send changes in the settings and configuration of MiniHPC to the online cloud. The settings will be sent 15 seconds after the last registered button press on the display.
– allow changes to the settings and configuration of MiniHPC via the online cloud or local network.
– permission to change settings via the REST API local network.
– permission to change settings via On-line cloud. Settings are sent to the device once every 60 seconds since MiniHPC is not permanently connected to the online cloud servers. The principle is that, at regular intervals when measured data is sent, a new configuration (if modified via the online cloud) is returned as a response to that HTTP request.
– permission to change settings via MQTT in the local network.
