Cooling Menu / 2.1 - Turn on/off cooling by
This section of the menu sets the conditions for initiating cooling.
– when this option is selected (which is the default), cooling will start as soon as cooling is activated on the main menu page (activated button with a snowflake). – cooling will be activated only if the on/off thermostat, which is connected by cable to the terminals S2, is switched on. – similar to the previous case, cooling will be activated by the signal from the on/off thermostat, but in this case the logic is inverted. When the thermostat is turned off, cooling will be activated. This is useful in cases where one thermostat is used for both heating and cooling. - cooling will start as soon as MiniHPC detects water flow in the circuit. Flow is controlled according to the conditions set in the menu 8.1 Flow Protection. Loss of flow will not trigger an error message, but cooling will be switched off. – if this option is selected, cooling will be activated/deactivated according to the setting of in the menu 2.2 Control temperature by with the configured hysteresis, which will be displayed after choosing this option.Example: The room temperature T1 is set to 25°C and the hysteresis is 0.5°C. Cooling will be activated if the room temperature rises above 25°C and will be deactivated if it drops below 24.5°C.
Input Thermostat S2 can be activated together with the options or . A combination of switching according to and is also possible. After activating a combination of these options, cooling will only be started if both conditions are met simultaneously.
This is useful, for example, if we want to use input S2, for instance, for activation during off-peak hours using HDO, or external switching, and at the same time also retain switching, for example, using temperature T1 as a thermostat.
When any of the above options is selected, cooling will only be activated if it is also enabled on the main menu page (activated button with a snowflake).
