Date / Time Menu
Date and time are required to set the timer for heating, cooling, or TPV. They are also needed for accurately recording error logs and for data sent to the online cloud.
If the MiniHPC is connected to the Internet via WiFi, it is possible to set the time via an Internet NTP server by clicking the NTP sync button with a predefined time zone. The device time zone can be adjusted via On-line cloud.
: by enabling this option, the device date and time will automatically be set according to the time zone set via On-line cloud after the device restarts, or when switching to summer/winter time. The currently used offset from UTC time is displayed on the NTP sync button.MiniHPC has a clock backup powered by a CR2032 battery. Therefore, if power is lost, it is not necessary to reset the time.
When you first connect your device to the cloud portal, the cloud portal will attempt to set the device's time zone automatically based on the IP address from which the device connects to the internet. If the time and time zone set via the NTP server do not match the current time zone, you can manually adjust the time zone via On-line cloud in the Settings section.
