Firmware Menu / 14.1 - Firmware Upgrade
If MiniHPC has internet access, it is possible to update its firmware to a newer version in this section of the menu.
On the left side, you need to select the language version of the firmware.
In the upper right corner, you will find information about the current firmware version installed on MiniHPC.
After pressing the button, a list of the last 3 available firmware versions for download will be retrieved from the internet.
After selecting the desired firmware, press the button. At that moment, the chosen firmware version will begin downloading to MiniHPC. This operation takes 1–2 minutes (depending on the speed of the internet connection). Once the download is complete, MiniHPC will automatically restart and boot with the new firmware. In case of an error during the download, or if power is interrupted during the upgrade, MiniHPC will start up with the original firmware version.
