Wi-Fi Menu / 9.5 - BT sensor / Dew point
If the MiniHPC has information available regarding relative air humidity and room temperature T1, whether via a connected NTC sensor, Bluetooth temperature and humidity sensor, or via an external sensor sent over LAN (REST API, MQTT,...), it will use these data to calculate the room dew point value and will not allow setting a cooling water temperature lower than this calculated dew point.
- this option turns on the BT scanner in MiniHPC and it will start reading data from available Bluetooth temperature and humidity sensors nearby. - if temperature from a Bluetooth sensor is available, activating this option will replace the temperature T1 from the NTC sensor with the temperature measured by the Bluetooth sensor. - This value can be used to adjust the calculated dew point offset.After activating the option a box displaying information about the calculated dew point as well as Bluetooth sensor data (temperature, relative humidity, battery voltage, battery level, RSSI, time since data reception) will appear at the bottom of the menu.
