Firmware Menu / 14.4 - Error automatic Reset
Menu 14.4
Menu 14.4 - Error automatic Reset
An error message that occurs on the MiniHPC can be cancelled either by tapping the display or by restarting the MiniHPC via On-line cloud.
Often, a random error appears on the outdoor unit, caused e.g. by a power supply voltage fluctuation, and this error subsequently shuts down the heating until it is cancelled by the user.
By activating the automatic error reset in this menu, such random errors can be automatically cancelled, thus ensuring the automatic restoration of heating without user intervention.
sets how many minutes after the error message is activated the error will be automatically deactivated.
determines what happens if another error occurs shortly after an automatic reset. If the error reappears after a reset, the system assumes it is not a random error but a permanent one, requiring user intervention. This time determines how long after the last automatic reset a subsequent error will be considered permanent. If another error occurs within this limit (default 2 hours), no further automatic reset will occur, and the system will remain permanently shut down until manually reset by the user.
