Cooling Menu / 2.2 - Control temperature by
This section of the menu is used to set the parameters for cooling regulation.
– when this option is selected, MiniHPC will regulate the output of the outdoor unit to maintain the room temperature at the set value. This is similar to temperature regulation in a conventional air conditioner. However, to prevent excessive cooling of the water in the system, the system also monitors the set temperature of the cooling water next to the item , so that the water from the heat exchanger is not colder than desired. – The output regulation is carried out so that a constant cooling water temperature is maintained, as set next to this item.
