MiniHPC Manual
English
Slovak
Introduction
Installation
Hydraulic connection
Electric connection
Initial setup
Menu
Heating
1.1 Turn on/off heating by
1.2 Control temperature by
1.3 Equithermal regulation
1.4 Timer
1.5 Electric heater R2
1.6 Circulation pump R3
Cooling
2.1 Turn on/off cooling by
2.2 Control temperature by
2.3 Timer
2.4 Circulation pump R3
2.5 3-way valve R5
2.6 Dew point / BT sensor
DHW
3.1 DHW temperatures
3.2 Timer
3.3 Anti-legionella
3.4 DHW HP conditions
3.5 Circulation pump R3
3.6 El. heater mode
3.7 3-way valve R4
Diagnostics
4.1 Outdoor unit
4.2 Indoor unit
4.3 Equithermal curve
Service
Statistics
6.1 Energy monitor
6.2 Heating overall stats
6.3 Cooling overall stats
6.4 DHW overall stats
6.5 Compressor statistics
Calibrations
7.1/7.2 NTC calibration
7.3 Flow sensor I1
7.4 input power
7.5 IDU heat temperature
7.6 IDU cool temperature
7.7 IDU DHW temperature
7.8 Freq. limit by outT
Protections
8.1 Flow protection
8.2 Frost protection
8.3 Anti blocking
8.4 Overload protection
8.5 ODU heating cable
Wi-Fi
9.1 WiFi station
9.2 WiFi AP
9.3 WEB ID
9.4 Permissions
Screen
10.1 Notification bar
10.2 Favourite menu
Logs
Date / time
Outdoor unit
13.1 Manual defrost
13.2 Power limit
13.3 Night mode
13.4 Quiet mode
13.5 Defrost control
13.6 Defrost trigger
13.7 EEV control
Firmware
14.1 Firmware upgrade
14.2 Restore defaults
14.3 User presmissons
Communication
On-line cloud
MQTT
REST API
Home Assistant
Bluetooth
Supported air conditioners
Technical data
DHW Menu / 3.5 - Circulation Pump R3
Menu 3.5 - Circulation Pump R3
Turn-off Delay
of the circulation pump after DHW heating is switched off.
Previous page
Next page
3.6 El. heater mode
