Diagnostics Menu / 4.2 - Indoor Unit
Current status of the sensors measured on MiniHPC and the status of the output relays.
: indoor temperature (by default via an NTC sensor, or the value from the sensor, or a value sent by an external sensor via LAN) : heating water temperature at the heat exchanger inlet : heating water temperature at the heat exchanger outlet : heating water temperature after electric supplementary heating : DHW temperature in the storage boiler : temperature of the liquid refrigerant on the thin refrigerant pipe of the heat exchanger : the current temperature set by the regulator (it may be either fixed or variable, influenced by equithermal regulation or a timer) : status of the output relay for electric DHW heating : status of the output relay for electric space heating : status of the output relay for the circulation pump in the heating circuit : status of the output relay for the 3-way valve for DHW heating : status of the output relay for the 3-way valve for cooling : status of the signal input from the heating water flow sensor : status of the signal input from the on/off thermostat : current heating water flow measured by the flow sensor I1 : value of the room's relative humidity measured by the sensor, or sent by an external sensor via LAN : dew point value (this value is displayed only if MiniHPC has available information about temperature T1 and relative humidity)
