DHW Menu / 3.1 - DHW Temperatures
MiniHPC enables DHW heating using the outdoor air conditioning unit. This option must be activated via the option:
– the final DHW heating temperature; once this temperature is reached in the DHW boiler, heating is switched off.
– the difference between the target temperature and the temperature at which DHW heating is activated. DHW heating is activated when the DHW temperature drops below minus (in this case 55°C – 20°C = 35°C).
