Cooling Menu / 2.3 - Timer
By setting the timer, the set cooling temperature can be adjusted at 4 different times during the day. Both the time and the temperature offset can be adjusted.
On the right side of the screen, it is possible to choose which temperatures the timer will affect. By default, both 2 options are selected. – the timer will adjust set in the menu 2.2 Control temperature by – the timer will adjust the temperature of set in the menu 2.2 Control temperature by
