Wi-Fi Menu / 9.3 - WEB ID
WEB ID is a unique, 32-digit code generated by MiniHPC and allows access to On-line cloud services for control and monitoring of MiniHPC.
After scanning the QR code on the MiniHPC display, the user will be redirected to the web page device.minihpc.com, where they can log in or register a new account. They will then be prompted to add a new device to their account. The WEB ID should be pre-filled; if it is not, you must scan it again from MiniHPC on the page for adding a new device.
In case of suspicion of misuse of the current WEB ID, you can generate a new one and then add it to your web account by pressing and holding the button.
The WEB ID will not be reset in the event of a factory reset and remains unchanged.
