Cooling Menu / 2.5 - 3-way Valve R5
In this menu, you can adjust the switching of the 3-way valve connected to the output R5 (if used) during cooling. This option is useful when the cooling water from the heat exchanger is to be directed to ceiling cooling or fan coils rather than to underfloor heating.
- When the cooling is switched on, relay output R5 will be switched on. - Inverted logic of output R5.
